Sequence instruction for S7 and positioning
WilsonNC
Dec 2010
Murphy
24
Is there a sequencer instruction for S7, or does anyone have a function for one. I want to index a pointer into a DB of 20 DINT's. The outputed value will then be added and subtracted with another "window" value. The new value will be compared to the DINT value coming from a POS338 module. Sort of a crude position method, but it works fine with AB logic.
Does anyone have any ideas on the easiest way to accomplish this?
Example function to return the indexed value from an array of DINTs shown in the attached project.
Hi, Im looking for someone who has experience with PLC Programming that can help me out with a problem with a circuit I am trying to make...
1,602
What type of electromechanical switch does a sequence instruction replace?
2,083
Hi, I wrote a sequence loop using EQU and MOV instructions and would like to validate that i'm doing this properly. i attached a picture of the...
533
23
639
To sequence through multiple MSG instructions with a Studio 5k program what are some preferred methods?
584
