Serial communication between a PLC and a Microcontroller
Shohadawy
Aug 2008
Egypt
66
I'm performing a project in which I'm using a PLC from "altus" the brazilian Co., an Exter T100 touch panel from "Beijer" and an Atmel microcontroller.
As I could not send the instructions directly from the touch panel to the microcontroller I'm using the PLC as an intermediatte stage between them. Then I'm going to send the data and the instructions sent from the touch panel to the PLC to the microcontroller via serial port.
The problem is that these data is concerned with different process parts. How can the microcontroller know that the received data is for a specific part of the process?
I am working to control some objects using Weintek HMI through Fatek PLC. I wrote a simple program to control an output Y_0 using input X_0. I...
3,842
Hi Experts. I need your help, I wanna communicate a MIcro850 with L19ER CompactLogix through Serial communication (Modbus RTU). I am using...
2,171
problem in communication between micrologix 1200 & Panel View 600 Plus by serial DF1 Hello Friends i have to do communication between micrologix...
6,640
Hello everyone, I want to make a serial communication using Siemens S7-1200 with CM 1241 (RS-232) and communicate with my Arduino. Here is the...
9,853
Hello. I want to establish serial communication between the S7-300 and a raspberry pi. Toward that end, I'd like to begin by sending a simple 1 or...
7,321
