serial to parellel converter instead of centronic interface Possible?
Nauman
Jul 2004
Karachi , Naval Colony
Can we use serial to parellel converter instead of centronic interface while communicating S7-200 with Parallel Printer. (The software we are using is STep-7 MicroWin 32 Version 3.2)
Regards
I don't know the S7. This is general computer info.
Most printers need Windows to run. They don't have any "brains".
The driver won't pass through the converter. Many also need 2 way communication.
The only printers that will work are the old dot matrix type. Epson or Oki Data are the only 2 choices on the shelf today. $300-$400 range. You can also buy these with a serial option.
Nauman,
please clarify a little about what you're trying to do. If you mean 'can I send something from the S7-200 to a printer using a serial-to-parallel converter', then you skip one step. The interface of the S7-200 is NOT RS232, but RS485. So, you have to convert from RS485 to RS232 first. Fortunately, tis can be done with the PC/PPI cable you also need to program the S7-200. But the conversion is not enough. You also have to program the S7-200 to send something to the printer.
If you're question was to inquire if it was possible to list the program without using a computer, then the answer is no.
Kind regards,
Dear sirs,
Thanks for your replies you are right, "Making a program in s7200 is necessary with the cable pc/ppi" . We have obtaied the print outs by using a s7200's demo program that contains "free port and xmt port"
Looking for recommendations for USB-C to serial adapters. Mainly used to connect to SLC and PLC5 processors.
197
Does anyone know of an AOI using the user ASCII protocol select on the L6x controllers that will talk Modbus RTU using RS-485? Thanks, Trevor...
191
I have 9 field devices, three METSEPM5110 power meters and six ACE949-2 rs285 interface modules. I want to read this Modbus rtu data through rs485...
335
I have lm9030 program on my toughbook CF-29 cannot get my program to hook up with the serial port.
83
I have a project to setup base programs across multiple PLC platforms that can be used for Modbus communications to various sensors that have...
136
