servo valve and solenoid valave
What is the difference between servo valve and solenoid valave?
I really dont know how to answer this one but I will try. A "servo valve" is just that servo. Is a device used to provide mechanical control at a distance.
A "solenoid valave" A solenoid valve is an electromechanically operated valve. The valve is controlled by an electric current through a solenoid Coil.
What is the difference between hydraulic and pneumonic? Hydraulic using Fluid. "
Pneumatic " how it is spelled is using air.
A servo valve is a valve that has closed loop control of its position. Servo valves come in a variety of forms, including ones with solenoids.
A proportional valve is a valve that has a proportional solenoid that allows one to vary the power to the solenoid coil to vary the position of the valve from closed to 100% open. A proportional valve that has closed loop control of the position can be called a servo valve, but not all servo valves will use proportional solenoids as their driver. Some use a nozzle/flapper driven by a torque motor, some actually use a rotary motor. What makes it servo is the closed loop feedback. The closed loop feedback is not always electrical, it could be mechanical. For example one kind of hydraulic servo valve uses a stiff straight wire as a spring to apply force against a flapper.
Creative engineers have even made tradtional on/off type hydraulic valves work as a servo valve with fast sophisticated time proportioning closed loop control.
Hi, I am currently working on a thesis on programming a basic process tank, I need to control the servo valve and solenoid valve so that the water...
4,836
Good morning, We've had an issue with a couple of servo valves and was wondering if anyone had seen anything similar. After a drop in pressure...
121
I have been given a project where we need to use a servo valve to control hydraulic pressure, particularly the transient spikes seen during any...
6,384
Hi I'm a new employee and I have a background in computer engineering but I'm working as automation engineer so I'm confused in understanding...
3,869
Hey guys, I am new at this and trying to figure out a way to control the speed of a hydraulic rotary actuator such that it starts slowly ...
6,409
