Set bit in FactoryTalk View Studio
boneless
Feb 2008
OKC
1,628
Hi all,
On a rare occasion I am programming a PV1000, in FV Studio Machine Edition 7. I want to SET a bit with one button and reset it with the other. Seems easy enough.. But how do I do it?
My 2c...
Do that in the PLC. On every PVP I program, every single button is a "set" button. In the PLC, as when the bit is set, I unlatch it immediately and then turn on a separate bit in the PLC for one scan to do what I want the button to do. There are a lot of reasons for this which I can go into if you want, but ultimately I've found it to be by far the most robust and reliable way.
Code:
|  HMI_PB_Start     HMI_PB_Start
|------| |-------+-----( U )-|
|                |  HMI_Cmd_Start
You don't use the "HMI_PB_Start" tag anywhere but on this one rung. Everywhere else, you use the HMI_Cmd_Start tag. So in your case, you'd set up two "set" buttons, and two rungs like the one above. Then you'd use the first one to OTL the bit you ultimately want to manipulate, and the second one to OTU the bit.
But, to answer your question directly, the neatest way to do exactly what you're after is to use two macro buttons. Write one macro to set the bit to 1, and one to set the bit to 0.
Hi all,
The interlock push button will write a value to a tag. Set 1 button to 1 and the other to 0.
Interlock Push button it is! Thank you!
I am replacing a Beijer E1071 panel on a vessel currently fishing around Dutch Harbor, so trying to do it without changing any of my PLC code.
Thanks all!
Hi there, I want to set a bit when I navigate to a display in FactoryTalk ME. Is there a way to do such a simple task? I cannot do it on the...
5,655
What is the best way to set a bit over an ethernet/IP network on an Allen-Bradley ControlLogix Series PLC from a Windows PC. We have a program...
2,107
Hi all, Another odd question for you guys, Looking to try and set multiple bits to a single word register. Some context, I am using a Delta...
1,712
Merry Christmas to everyone!! Working on a prototype system using a Click PLC and a Red Lion G306. I am trying to set a bit in the PLC when I am...
2,102
I have an integer coming from an IO Link device into my PLC. The first 2 bits of the integer are digital status bits of 2 alarms in the device...
1,514
