[COLOR=Red]// Read all data from meter
// Some requires conversion
// Some is used for calcs
macro_command main()
int v, a, em111_s, mcb
float curr, volt, hz, temp_a, temp_v, temp_f
short check, f, status
bool em111_ok, em111_vonly
mcb = 32
// Get Data to do compare for lamp status
GetData(v, "GavazziMeters", "UPSO1L-N", 1)
GetData(a, "GavazziMeters", "UPSO1LC", 1)
GetData(f, "GavazziMeters", "UPSO1FREQ", 1)
GetData(check, "GavazziMeters", 3x, 4#8192, 1)
// Make integer values into floats
temp_v = v
temp_a = a
temp_f = f
// Do comparison for lamp status with function call
em111_s = em111_stat(v,a,mcb)
status = em111_s
em111_ok = em111_on(check)
// Divide data with function call to get
// real value
volt = l_volt(temp_v)
curr = ph_curr(temp_a)
hz = freq(temp_f)
// If voltage but no current make indicator flash
if status == 4 then
em111_vonly = true
else
em111_vonly = false
end if
// Set Data in Word for Word lamp
SetData(status,"Local HMI", LW, 303, 1)
SetData(em111_ok, "Local HMI", LB, 103, 1)
SetData(volt,"Local HMI",LW,60,1)
SetData(curr,"Local HMI",LW,62,1)
SetData(hz,"Local HMI", LW, 64, 1)
SetData(em111_vonly,"Local HMI", LB, 203, 1)
end macro_command[/COLOR]
