Set/Reset hangs
To eliminate the obvious, can you clarify the following:
Are there any other devices that can write to plc tags - HMI, other plcs, PCs?
Did you write all of the code yourself?
Is there any indirect addressing in the code?
Is there any block moves in the code?
Is there any PEEKs/POKEs in the code?
+1 on the trace.
Trace all the relevant variables.
"Sekvenser".Test_Seq_1
"Sekvenser".Test_Seq_2
"Conveyor_5.1_Outlet"
"Transferchain_7.3_1_Done"
And answer LDs questions.
Hi, I was testing my 1747-ASB for some I/O mapping last week. Today when I tried to power-on my chassis with 1747-ASB inside, the ASB just hang...
2,193
Hello, I still do not have equipment in to test. But the RTAC ladder does not have a timer reset coil. I wonder if a reset coil on Timer.IN is...
79
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
39
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
352
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
92
