set theory
George2
May 2004
London
I'm new to this forum but would like to ask a basic question
i.e. given that Set Theory is said to be an example of a
Boolean algebra,then how is it Boolean??
In the normal Boolean algebra we only have two possible
values of a variable these being 0 and 1 but I can't see
how this two valued concepts apply to sets.
This probably isn't the place for this level of question. But, as a guess at an answer to you question, a given item either is or is not a member of a given set. That's a binary state. It isn't like fuzzy logic where an item can be somewhat or partially a member of a set.
Hello, I still do not have equipment in to test. But the RTAC ladder does not have a timer reset coil. I wonder if a reset coil on Timer.IN is...
75
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
39
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
352
Omron AD081-V1 Analog Input Card Offset & Gain Adjustment Entering Adjustment Mode 1. Set the input card in adjustment mode (Turn ON Dip SW No-1)...
107
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
91
