jakeparsons03
Hello,
So I am trying to set the parameters of a pf523 with a Micro850 PLC all done over CCW. I've set it up before with RSLogix5000 where when you add the VFD to the project, tags will show up that allow you to set the VFD parameters. When I tried to do it over CCW, tags don't show up.
Long story short, I need to write a program that controls the VFD and I was wondering if anyone knew how I could interface with it from the PLC. Thank you.
EDIT: I have the VFD and PLC both set up in the project. I ran through the VFD wizard already. I just need to make the connection between the two.
