Setting up Generic Ethernet Module
lncabin
Nov 2014
LA
I've got a device sending me a <STX>data1;data2;...;datai<ETX> message through ethernet. Is it possible to determine the assembly instance information from this message?
I assume you're using ControlLogix.
In this case "generic Ethernet module" is a misnomer. It should say "Generic EtherNet/IP Adapter Device".
Such an entry in the I/O tree of the ControlLogix/CompactLogix project has to be an EtherNet/IP Class 1 Adapter. It's not literally "some generic device on Ethernet".
You probably need some kind of ASCII-to-EtherNet/IP gateway, or you need to write an application for the generic sockets feature.
What exact device is it ?
Hello, We are having trouble setting up a generic ethernet module for a Yaskawa GA80U4168 drive in RSLogix 5000 Version 20.01. All of the...
652
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
992
SELECTED NEW FILE SELECTED PROCESSOR TYPE SELECTED I/O CONFIGURATIONS IM UNABLE TO CONFIGURE MY I/O’S. I HAVE A PAPER COPY OF A PROGRAM AND I...
103
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
277
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
104
