Setting up PC Station using Siemens CP5511
Rusty_K
Mar 2004
Norway
73
Hello,
I've set up a PC Station on my laptop using Step7 ver 5.2 and Simatic Net V6.2 CD11/2003 on a Windows 2000 Professional SP4 platform. I initially had loads of problems getting my CP5511 card to work (VXD/DLL errors) with an older version of Simatic Net until I upgraded to Simatic Net V6.2 CD11/2003 (I have a similar set up working fine on 2 other computers except they were using CP5613 cards, the older version of Simatic Net : ver 6.0 SP4, Win 2000 Pro & Adv. Server, both with SP3). I was then able to successfully configure my laptop as a PC station on our profibus network and can see all the Bus Nodes in the Configuration Console, which I was unable to do previously. On my OPC server I have several (about 26) S7 connections. I now find that some of them work (about 8 at a time ) and some of them do not. I initially thought it might have been a configuration problem but it's highly unlikely since all I did was copy, paste and rename one of the currently running PC stations in NetPro. Furthermore, the S7 connections which work/fail change every time I disconnect, remove and reconnect my CP5511 card. I'm really at a loss for the moment. Does anyone have any suggestions?
Cheers
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
914
SELECTED NEW FILE SELECTED PROCESSOR TYPE SELECTED I/O CONFIGURATIONS IM UNABLE TO CONFIGURE MY I/O’S. I HAVE A PAPER COPY OF A PROGRAM AND I...
93
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
254
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
94
Hello. I am trying to use a Prosoft AN-X4 to improve the communications for a new panelview plus 7. This is going from a SLC-500 through DH+ to a...
304
