SetupMailServer SMTP Question
spaceacealpha
Sep 2009
Tennessee
79
I'm trying to use SMTP.GMAIL.COM but how do I format the string to have the username, password and port? I'm using a ENBT/A and following the manual on creating this. It runs but faults out for "error processing connection related service". Thanks, Darren
EmailConfigScreen="[email protected]$r$lpassword$r$l587"
I guess you have created the "Email Account with gmail" ?
I also thought gmail used port 465??
I also forgot, you have to at least log in to the new account once to answer some authentication questions before they allow account usage.
ENBT does not work with secured SMTP like GMAL
You must have local network server that does not require authentication
We have been using AuthSMTP to get around the authentication requirements for our systems (mostly Red Lion HMIs) that can't do authenticated emails. It has been very reliable and inexpensive for us. One thing I had to do at the outset was to contact AuthSMTP and inform them that I needed a static mail server IP address. There is no guarantee that they won't someday change that IP address, but after over two years so far it has not happened.
I also seem to recall that the address of the initiator could not be a gmail account. So we set up a "dummy" generically named email account with our company domain as the sender for our systems to use.
https://www.authsmtp.com/
I've got a program that talks raw unencoded SMTP to send emails. I've used it where the customer has a local email server so the unencoded SMTP...
156
I have an application where I am sending emails and SMS text messages via an SMTP server, using MSG instructions. Everything works fine, except...
1,224
We currently use GMail accounts for sending email alarms from quite a few HMI projects. Specifically C-More HMIs and AVEVA Edge runtimes. To...
7,544
I really need any tutorial about mail send function, please..
1,836
Hello PLC folks, I have never done any email application on PLCs before. This will be my first time so I have some questions and I would...
2,002
