SEW BSG Brake Control Module
MHennel
Jun 2002
Cincinnati, OH
64
I have an SEW motor that has a BSG Brake Control Module. The BSG is 24VDC electronic switching device. Is it possible to control this from an AB Armor block I/O point, or is it to high a current draw? I am not clear from the data I have found and I am not an expert by any means on motor brakes
Lynxx777, you are correct of course. See attached doc.
I recently used a BSG module with a brake that ended up around 5A. I obviously didn't think that through. Shouldn't post after days like that...
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
199
Hi , I am trying to replace an old inverter with a new one and its giving me issues . Once the new one was installed , the S7-300 PLC started...
127
Hello Everyone. Looking to see if any of you have encountered an issue with these drives. We have a major installation with around 30 of these...
95
Hi Friends, I am facing a problem with encoder adjustment in Sew Electric Cylinder CMS71L. encoder using is Sick Hiperface Drive is MOVIDRIVE...
17
789
Communication between devices will stop working for a certain period of time. I caught the error message using WireShark. I cannot identify the...
102
