SEW iPos Programming
hgultekin86
Dec 2012
Highland Park
I am not familiar with SEW and currently doing a project where I need to establish a speed synchronization between a master and a slave axes. Master's trapezoidal velocity information(acceleration time and target velocity) will be coming from an Omron PLC via EtherCAT.
I have two questions, The first one is how to increase the number of PDOs (Process Data Output) from Omron PLC to SEW MDX61 Servo Drive? Is there a register or a parameter value in the SEW MoviTools Motion Studio so that I can modify this parameter to increase the number of configured PDOs?
The second question is, how can I access the parameter 751, scaling set point so that I can send this ratio from PLC to SEW Servo Drive. What is the syntax in IPOS programming to access and send a value into parameter 751?
Thank you all.
Hi All, I'm just writing an application with IPOS, which is similar to the built in positioning application from SEW. In addition to the functions...
2,925
Hi, I’m new working with SEW specially with Movidrive with DEH11B encoder, Movitrac with FSC11B and DOP panel – right now I do not have the...
18
10,266
Somebody know how to program an Ipos routine, for read and write a Position in a SEW drive...i use Devicenet, i pass the last two weeks trying to...
3,819
any movitools programming experient to share ? about to write positioning program using SEW movitools ipos plus. must read few manual and start...
25
35,221
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
222
