sheet edge detectors
ldavis7999
Sep 2003
Minnesota
I need recommendations for a sheet edge sensor for roofing manufacturer. We are currently using 2 contrast sensing photo eyes and because of sand, slate fumes and steam we need to find a more reliable solution. the fiberglass sheet is just exiting the asphalt coater so it is quite hot (350F) and I want to go to a thermal sensor as it would not see the dirt as readily. Does anyone have any experience sensing sheet edge this way? I will be against a water cooled drum and the output will be controlling 3 Yaskawa servos that can be programmed for either digital or analog control.
thanks...Larry
I dont have experience with that but I saw someone who used Ultra Sonic sensor Reciver&Transmiter.for edge control.
Just idea.
we currently are using laser photo eyes, we have tried color and contrast sensing...but the major problems are with them getting to dirty within an hour or the dirt and sand on the drum causing false readings. we have fife guides elsewhere on the line and they work great but in this spot anything close to the product is gonna get trashed. what i am considering is an infrared scanner placed 2 to 4 feet away...thermal contrast between the sheet and the drum should be more than adequate, however the scanners we used in the steel industry were good only down to 450F and i dont know what else is available
larry
unfortunatly thru beams wont work in this location, the sensor has to be mounted to the moving stand and thus we are restricted to the sheet against the drum. we also have air purge systems installed but that has just been fogging our lenses
Larry,
please state how accurate, and how fast the edge detection must work.
Do you need an analog value for where the edge is, or is it sufficient with a fixed ON/OFF point.
Hello, My background is IT, and I have very little (effectively zero) understanding of PLCs. I have been tasked with acquiring version 2 of...
97
Hey guys how would you approach the spreadsheet screen part? I searched and everyone points out that using parameters to display this information...
756
Is it possible to pull information from a specific cell in an excel spreadsheet and use it in a program? I am wanting to display a time amount for...
1,166
does anyone know how or If you can Change the default sheet size to A3 for New FBD's so that when you create a new FBD during online editing it...
765
Hello all, I'm using Ignition as the HMI for a project. I do not have physical access to a PLC to download our project on to for development...
17
4,419
