Shift Register for the Bytronic ICT3
mitureg
May 2013
Canada
199
Greethings everybody. This is my first thread so bare with me. I am a PLC enthusiast, just started a few months ago.
I got a question with regards to shift register in RSlogix.
How is it possible to trigger an output with a shifting bit in a register. So far here's what I have:
Figure 1 (see attachment)
Each time IP4 is energized it shifts the content of the bit address B3:1/1 to the right, as a clock.
Now, when (or how) can the content of an address be used to trigger an output? Let say, of the top of my head, that one possibility would be to have an output triggered when a bit reaches a position in the file #N7:0. As it starts from the left at position N7:0/15 (of a 16 bytes word), can it trigger an output when it reaches N7:0/1 ?
Is there a more versatile way to trigger an output from a bit within a shift register, no matter where it is in the register?
Thank you :site:
That can be done as simply as this:
| N7:0/1 O:0.0/1
..and that can be done like this:
|  +--------------+                 O:0.0/1
|--| NEQ |-------------------( )
| |Source A: N7:0|
| |Source B: 0 |
Could you explain your application? I'm asking because maybe there could be a simpler way to achieve your goal without having to use BSR.
Hi Anirban, can you explain a bit more what is the purpose of the value within this NEQ application ? Thank you
Code:
|   |Source A: N7:0|
|   |Source B: 0     |
You had asked for a way to trigger an output if any of the bits of a certain register became 1.
If any bit of a register becomes high then it's decimal value as a whole will be no longer be equal to 0.So I suggested using NEQ(Not equal to) instruction to compare the register value with 0. As soon as any bit in N7:0 becomes high this instruction will turn on O:0.0/1.
hi all, im having a problem programming the bytronic itc1. It regards pointer register and data registers. The information i have is as follows...
2,821
I am attempting to reject a bottle If the label fails. The rejection works fine at normal line speed but at low speed the rejector fires (air...
35
1,161
Hi guys, I am pretty new when it comes to programming. I am working with CX-Programmer and I am having a problem where I have a sensor on my...
695
Hi all, i have a very slow indexing machine where we are looking to make everything as bulletproof as possible, money is not much of a factor...
3,070
Good morning (EST), I am trying to implement the code below in on an S7-1200. It's barely half a dozen instructions, but I am stuck; I have not...
26
5,697
