Shift Register?
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Good day all. I would like to know what the function of a shift register instruction is. I havnen't seen it in a program yet, however, looking through the SLC 500 Reference Manual I seen it and just wondered if I could get an understandable explaination. Thank you.
take a look at the figure below from thelearningpit's bottling line exercise ...
http://www.thelearningpit.com/lp/doc/bot/bottle.html
the idea is that sensors can check each bottle at ONE point in the line (tall, broken, etc.) – but then the information doesn't actually get USED until some OTHER point - further down the line ...
you can use a Shift Register to move the "information flag bit" down through the conveyor line step-by-step along with the bottle's movement ...
then when the bottle finally gets to the "fill" station you can use the flag's status to decide whether to fill a "short" bottle or a "tall" bottle ...
I am attempting to reject a bottle If the label fails. The rejection works fine at normal line speed but at low speed the rejector fires (air...
35
1,150
Hi guys, I am pretty new when it comes to programming. I am working with CX-Programmer and I am having a problem where I have a sensor on my...
688
Hi all, i have a very slow indexing machine where we are looking to make everything as bulletproof as possible, money is not much of a factor...
3,066
Good morning (EST), I am trying to implement the code below in on an S7-1200. It's barely half a dozen instructions, but I am stuck; I have not...
26
5,675
Hi everyone I am completely new to using shift registers and am a bit stuck, my shift register works as should, it is for an overhead conveyor...
55
15,622
