Showing the number pad for numeric input
JohnJPhillips
Jun 2016
Illinois
30
Hi guys,
Got my prior problem narrowed down.
The issue I'm having now is that in our hmi most of the numeric input fields have a popup for the little number pad to enter the value.
I can't for the life of me come across any way to make this pad show up. When I make the numeric input you have to enter the value on a physical keyboard.
My problem is that most of the hmis are touch screens and this would be inconvenient. Does anyone know how to format so that the little calculator style pad pops up?
Are you using the Numeric Input Enable FTVS object?
If so, under its Properties/Numeric tab you have the Keypad, Scratchpad or None Pop-up Settings; obviously None would not get you anywhere; choose Keypad.
Objects > Numeric and String > Numeric Input Enabled
double click on the object after it's placed and the "numeric" tab has that option
Can you generate an email that will show the " Real" number of a tag, say a totalizer.oldtotal. I pulled up the documentation for getting "text...
1,796
Good morning, We've had an issue with a couple of servo valves and was wondering if anyone had seen anything similar. After a drop in pressure...
121
Hello, I am using a Hitachi Micro EHV+ for a small project, and I wanted to have a Web visu, done with Codesys V3.5 SP13 Patch 2. I test the...
410
Hello. I am working in FTVSE v8. I have many trends set up some of them work others do not. The ones that don't work show the foot print of the...
247
Hello everyone, I am working in a platform and we installed FTV CLIENT SE V 12 IN ALL THE CLIENTS COMPUTERS, we have 6 clients and only 1 is not...
111
