SHRB function
I use it to track mutiple steel or titanium
bars being processed through a peeling
line. Several may be in the machine at one
time. If I used a counter it would reset before the previous bars reached processing
points such as clamp , bar reject , bar
eject , etc.
Hello fellas Im having trouble downloading this program to s7-200. (Se attachment) No problem in program but just before it ends the download it...
1,697
I am using a SHRB for registers between 4082 to 4084. (see pic SHRB) I am using an interface to sometimes directly set values. So in the PLC...
1,343
I am using the SHRB instruction to shift bits with TISOFT. I was wondering if it is possible to set bits (by an interface) that are used by this...
2,725
I want to use a shift register in S7 similiar to the Allen-Bradley BSL/BSR shift instructions. I found the FC92 bit shift register under standard...
17
10,883
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
134
