shutdown and control valves manufacture
shkoko2000
May 2011
cairo
296
Dear all,
please i want your help to rank manufacture for shutdown and control valves as i work on a project and the vendor will not bring fisher valves as the time is not sufficient.
you have asked a vague question.
pneumatics valves?
Hydraulic valve?
chemical valve, what type of chemicals?
standard valves or hazardous environment classification?
control voltage?
we need more information.
james
I have nodal compression package consists fo separator, surge vessel and compressor.we usually use fisher and bettis actuator(emerson products) at our main plant.Now a new small plant will installed at another site (nodal compression package consists fo separator, surge vessel and compressor.)but the problem the delivery time will be change if i order emerson products. So i want to use another brand with the same quality. I know some brands for control valves like CVS, flowserve and masonelian but i can choose between them from best quality point of view and if there is another type please mention it ( all of them operated with air supply).For shutdown valves i know biffi (morin) only so i want another brands with high quality( also shutdown valves will operated pnumatically). Please your support is highly appreciated .
We have mostly Fisher but there’s a few Jordan in use that have been fine.
I'm upgrading an existing machine with a Honeywell HC900 controller, and I'm trying to do some data processing in the controller. I have variables...
56
I have been using a FX3G PLC in a control panel of a special purpose machine(SPM) and it was working fine but during one of the operational cycle...
1,903
Hey guys, got a little situation here which i am not sure if its something viable. We are using a 16 slot chassis with 7 IB8 input cards and 8...
1,809
Hello all, due to Covid-19, our site is facing the possibility of shutdown. I run a few PLC systems (controlllogix, compaclogix). Any shutdown...
2,400
I have an older G310 - so stuck with Crimson 2, but although it is not nearly as cool, I'm doing ok with it. The issue I have is that I have a...
2,492
