Siemens - 3RW40746BB44
that's siemens 3rw40 series of big soft starters with soft stop and two-phase regulation, i'll assume you know power contacts, then from left to right:
A1,A2 - coil contact
1 - 24VDC +
2 - Not used
3 - Start/Stop
13 - NO contact
14/24 - NO/NC common
23 - NC contact
95 - OL common
96 - OL NC
98 - OL NO
if that is what you asked
don't forget the settings, and reset mode to check
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
110
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
155
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
169
113
332
