siemens 6ES7322-5GH00-0AB0 wiring question
bobmac
Jun 2012
michigan
http://imgur.com/pFO5U
(sorry image wouldnt link directly)
siemens 6ES7322-5GH00-0AB0 safe out card .
we are having issues with this card and the wiring . it says it can be ac or dc but the supply is dc. I know on a AB relay out card it acts like a dry contact . this one seems to show it drives both pos and neg. other coworkers do not think it works this way. what do you guys think? Siemens manual is useless. thanks,
the 24Vdc is the supply for the card
the wiring diagram uses standard symbols
the rectangular box is the relay coil
the round circle with both the wave and straight line is the supply you use
AC or DC
according to the Siemens website this card has 120 V max AC
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
146
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
79
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
150
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
181
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
182
