Siemens 6RA70 with profibus
nathan66669
May 2011
Vevay Indiana
Hey guys,
I've read what I think is every single thread here about profibus with this drive (pretty much learned everything from here!) My question is this:
If I use control word 1 from profibus, do I still need any of the hard wired I/O? The book mentions terminal 37/38 are always used to control word 1 and never able to be changed, but are they ignored if I change P648 to K3001? It doesn't specify anywhere. Also, the same goes for the hard wired E-Stop on terminal 105(or 107). It goes into control word 1 bit 2.
I'm trying to get a good set of wiring schematics drawn up before the drive needs to be installed, so I am not able to test it first and would save a heap of time if I knew this.
Hi Guys, I have a new 4 Quadrant 6ra70 DC Master from Siemens; it is basically to replace an existing 6RA24. I have a digital input going into the...
1,981
Hi there, Following procedure for updating software on 6RA7013, stuck at step 5 (for those who have the manual) where you open a dos window and...
4,318
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
97
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
291
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
105
