Siemens coros op25
mhmtfthnl
Nov 2003
everywhere I can go
42
Hello everybody...
We have a problem about Siemens Coros OP 25. How can we back up and restore configuration and firmware program for that operator panel.Can it performed by Protool or Prosave. And which cable must we use to communicate with OP. Thank you for your concern.
Hi mhmtfthnl (how do you pronounce that !?).
THIS post talks about backing up the application on the OP25 to a flash card.
Notice that it will only be possible if the backup function is pragrammed into a button on the unit. If no such function can be found anywhere then you are out of luck.
Try to browse all the screens of the OP25.
Maybe there is a screen called "maintenance" or "OP25 functions" or something like that.
I would contact the original programmer, to get the source file.
Your other problem is that OP25 is obsolete and it can be difficult to find a spare.
With the original program you can both it to another OP25, and you can convert the application so that it can be downloaded to an OP27 or OP270-6.
I just got my hands on a Siemens Coros OP25 but I have no idea on how to program it... After reading on this site I found out that I must use...
4,412
Hi everyone, I'm on a facility running a PLC-5 with a Siemens Coros OP25 as an HMI, now, I'm quite familiar with the PLC but I'm curious to see...
6,474
HI, I currently have an issue with SIEMENS hardware with which i need help! I have a Siemens COROS OP 35 running a thermoglide which is old and...
2,062
I need the program loading method (Step by step procedure)of PC->PLC and PLC->PC for SIEMENS Coros OP15. Any one please help me to do this...
4,673
Hi, We have installed Logo in one project. I want to connect Logo 230RC PLC with Coros OP5 HMI. Is there any possible way to connect them ...
1,715
