Siemens CP PCIx card for Small Form Factor
Adenitz
Feb 2010
tir
41
Hello automation experts,
does Siemens manufacture CP cards for PC, such as CP5622 in SFF or low profile form i.e. to be used in a PC with SFF chasis?
Thank you!
What bus are you looking for? What size do you need it to be?
I've seen PC104 cards, PCI cards, and PCI express cards. I haven't seen anything specifically intended for small chassis, but there might be one that happens to work for you.
CP5623 is a small formfactor for PCIexpress X1.
https://mall.industry.siemens.com/mall/en/dk/Catalog/Products/10045053?tree=CatalogTree
You have to check if it will fit or not.
There are a couple of other alternatives as well. For example the CP5711 for USB:
https://mall.industry.siemens.com/mall/en/dk/Catalog/Products/10044661?tree=CatalogTree
Or a 3rd party Ethernet/Profibus gateway, such as this:
https://www.deltalogic.de/produkte/s7-adapter/accon-netlink-pro-compact
There are several vendors that sell almost the same adapter.
I would prefer this one if you absolutely must connect to a Profibus network.
Is there a particular reason why it must be for Profibus ? Profibus is obsolete and should not be chosen for a new system.
Us network
Dear Jesper, thank you for the feedback. The profibus network is already there. It is rather old setup. I'm just replacing failed computer with anther one. The rest of the system is not changed. We already have one spare Business workstation, so I thought it would be a good idea to use it. I need profibus card that will fit SFF casing. Also DP/USB adapter cannwork but I'm not suremif this can be a long term solution.
Thanks Jasper. It is important to know that this USB/DP adapter can work 24/7. This seems to be a very good solution.
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
98
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
300
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
106
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
160
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
197
