Siemens CPU 315 PN I/O
eibe
Jan 2012
Bergen
22
Hi.
I'm using a Siemens CPU 315-2 PN/DP.
The PN interface is used to communicate with other PLC's and computers via an ethernet switch, while the DP interface is connected to a Profibus DP slave module (WAGO).
Is it possible to use the PN interface to connect to an ethernet slave (PN IO), for instance ET200, at the same time as I use it for connection to other CPU's and computers (with s7 connections)?
If so, can the ethernet slave be connected via the switch (on the same network as the other CPU's/computers), or must the two networks be separated, i.e. using port 1 on the CPU for PN IO, and port 2 for S7 connections to other PLC's (or vice versa)?
Eibe
Yes.
Yes. The switch should be Profinet rated.
That is a sensible way to do it.
I'll preface this by saying this is the first time I've worked on a Siemens system and I'm fairly unfamiliar with them. I might mess up some of...
29
752
Hi We were having a few power cuts and the CPU would not work. I had to reset the memory and he CPU would read from the memory card and start...
3,170
Hi, Can anyone explain the difference between rebooting a Siemens CPU 315-2 PN/DP, either by setting the switch into stop and back into run...
2,687
I have a Siemens S7 300 CPU 315-2 PN/DP PLC and CP 342-5. IM Module is configured via ethernet port. I have two profibus network. One on CPU and...
4,143
Hi All. I'm creating several diagnostic screens for the maintenance personnel, displaying the I/O status. Do you know if it's possible to get...
3,713
