Siemens CPU315-2 PN/DP Edit Ethernet Node
shaulapto
Feb 2004
Raanana,Israel
53
I need to make a change in the Hardware Configuration of a Siemens
CPU315-2 2PN/DP.
But I'm not able to download the modified configuration to the CPU and not able to find the CPU (Edit Ethernet Node,browse).
Although I am able to go online,upload and download program blocks.
May be someone can help.Thanks.
Hi
Check Object Properties for your Project
In "General" Tab you have Field "USE"
If you have there PCS7 then you cant download HW. You have to switch to Step 7
Dear Sirs, I had a problem with CP 343-1 with CPU315-2DP.I had newly add the CP343-1 Ethernet module to the hardware to allow me to access this...
2,649
I have never installed a brand new CPU before. But, I need to take an existing project from a CPU315 and put it in a CPU319 because we are...
3,139
Hi folks, I could really use some help - I am trying to connect CP340 with my PC by RS232 protocol. I need to send some characters to PC from...
1,904
I'm using a CPU315-2 DP and I can't find any information in the manual regarding the analogue current outputs, such as the addresses and which...
1,859
Hi, I am a student and trying to wire a Siemens CPU315-2DP Analogue Module with a 0-10V and 4-20mA sensors. The Specs of the PLC are: CPU315-2DP...
6,551
