Siemens drives : direct data exchange
Plc_User
Dec 2005
Belgium
317
Has anyone experience with 'direct data exchange' on Siemens drives which are on profibus? This configuration is used for communication between drives on the same profibus whithout passing the data to the master (data is broadcasted). I would like to use this on Sinamics G120 drives for speed synchronisation. The drives are on the profibus that also goes to the field io. The bus speed is 1.5M.
What can I expect for the communication speed? Will this be as fast as coupling the drives with analog inputs and outputs to eachother?
What about the extra busload?
Slave to slave communication
Is there realy anyone who has experience with slave tot slave communication (also called internode communication or direct data exchange). Preferebly with drive, but it is also possibly between plc's. I have troubles setting up the configuration.
Please reply if you have experiences.
Havent tried it myself, but a quick search on Siemens support immediately reveals http://support.automation.siemens.com/WW/view/en/22421343 for drive-to-drive comms. Have you seen that already ?
For knowing how fast the data exchange is, if you have setup the configuration including the drive-to-drive part, you can investigate the Profibus Bus Parameters. TTrtyp is the "typical" token rotation time which is exactly what the name says. Without knowing too much about slave-to-slave comms, I would guess that all data is exchanged within that Token rotation time.
Siemens drives : slave to slave communication
Thanks for your quick reply. But I already based my tests on that case in the Siemens Support. I only have G120 drives so I cannot check the configuration in the example with MM4. But if I try something comparable with Sinamics G120 I always get a busfault on the drive configured for direct data exchange.
The supporline of Siemens could not help me so far, so I hoped someone had already used it before.
Hello, Does anyone have experience integrating RX3i PLCs and Siemens drives? I'm trying to use this line of GE PLCs and a variety of the new...
2,044
Dear Sirs, My boss got me some old used 'somebody else's spare' MasterDrives to stow as spares for our machines. Some are tagged as 'will...
2,400
Dear Sirs, What I need is some insight into 'Forming' the capacitors (or re-forming) inside a Siemens Rectifier. The box turns 480 Vac into...
3,301
Hello all! Hopefully a simple one. We have got a few G120 drives installed on site of late, however we have been left in a state with no software...
1,857
hello to everyone, please guide me how to communicate ABB ACS800 drives and siemens s7-400 drives via profibus , actually i m familiar about...
6,396
