Siemens, ET200S, Add new Safety Card
RoosterFry
Feb 2014
Chattanooga
I know I can add a new I/O module to an existing ET200s rack by placing it at the end of the rack.
But, is it possible to insert a new I/O module into the rack.
For example; My ET200s a PME (slot 1), 2 safety input cards (slot 2 and 3), 4 standard input cards (slots 4-7), and 4 standard output cards (slots 8-11). I need to add a new safety input card, but would like to place it at slot 4, thus shifting all the standard I/Os down. How can I do this in the Hardware Config?
I do not see an insert "line before or after" like a Data Block editor shows.
Or, will I have to manually move each card down the page, and then replace the object in slot 4 with the new Safety Input module?
Yes, to the best of my knowledge you will have to do it that way.
And pay attention that the software doesn't change the addressing on you.
Hi Rooster
Beware that you'll need a new power module, if you want your safety to meet SIL 3.
You are not allowed to put Safe-modules after standard modules, if you want SIL 3.
I was trying to communicate between Siemens ET200S IM-151-8 PN/DP CPU to Rockwell Allen Bradley L73 through Hilscher Gateway NT100-RE-EN. Using...
118
Hi there, I'm having major issues in connecting a Siemens S7-300 315 with an ET200S through Profibus. I've tried many methods but I'm really...
2,841
i am working with et200s in my company but i have an issue here.all the output devices connected to it is not running what could be the problem
18
5,976
I'm configuring a profinet network in TIA portal v13, comprising the following components: S71500/ET200MP processor TP1200 HMI 2 x IM 155-6 PN...
2,274
Hi all, I have successfully connected my new wirelessHART sensors to the master station, but am struggling to find a comprehensive guide on how...
1,710
