Siemens Ethernet Lean card vs. Ethernet Adaptor
uptown47
Feb 2008
Over there, next to those boxes
1,146
Hi all,
I'm looking at upgrading some of our PLCs on to ethernet so that the lads can then access them wirelessly.
We have a few of the NetLink Pro adaptors (http://www.helmholz.de/prod.d,80_92_93.html?p_id=142)
These work fine but I was thinking of going down the route of putting in Ethernet Lean cards (CP 343-1 LEAN 6GK7-343-1CX10-0XE0).
Some of our PLCs have HMIs connected to both the MPI and Profibus ports and I wondered if it possible to program the HMI's on both of these ports via the Ethernet Lean card ?
The NetLink Pro adaptor just plugs into either the MPI or the Profibus port and therefore would only allow a user to program the HMI in that port.
Also the Netlink Pro, despite being ethernet, is obviously slowed down to the speed of the network its connecting to.
So, I'm thinking (if I'm right) that I could put in Ethernet Lean cards, get access to both the MPI and Profi ports AND have full ethernet speeds...
Is this correct?
Many thanks for any info you can give me
Cheers
The LEAN cards support S7 routing, which is good.
The only other blocking point might be the HMI used.
This link has some nice info on your question
The CP343-1 LEAN will allow you to connect to any other partner via the connected CPU and its further connected networks.
All the devices in question must be integrated into one STEP7 project, this for the routing to function.
Be aware that you will not get "full ethernet speed" this way. The CP343-1 LEAN connects via the slow MPI backplane at 187.5 kbps.
So, to clarify:
You do not have to enable something in any configuration in order to get the routing?
The only thing you need to do is to make sure that the devices are in the same Step7 project?
Andreas
So, to clarify:
Andreas
Yes. Your PG/PC also has to be part of this STEP7 project (as a PG/PC or as a PC Station).
The HW Config has to be downloaded from NetPro to all CPUs. This to update the routing tables.
Hi! I have a question regarding ethernet communication with a Siemens S7-312C and 343-1 Lean. For some time I´ve been using the S7NetPlus...
3,309
we have a 1Gbps network can we connect leancards on that speed ?
3,054
172
Hi, I have a 1214 on ip 192.168.0.100. This is connected to other modules through a switch on same network. I need to connect this to a company...
188
Can I open a Port from a Siemens PLC to an ethernet device Device will be at 192.168.0.1 and I need to open port 2112 (Upd?) Then once the...
315
