Siemens FB58 TCONT_CP PID Controller
orense
Apr 2006
Norway
196
Hello,
I am a little bit confused about the PID settings in this controller.
If you take a look into the instance DB, there is a large amount of settings.
In DBD124, DBD128, and DBD132 there are PID settings.
However, when you change the PID settings in the Parameter View of this DB, then you do not change these settings. There are PID settings in DBD166, DBD170, and DBD174. These are the PID settings that you change by using parameter view.
Do any of you guys know what the PID settings in DBD124 --- are used for.
I have read the manual, but can't find any clear solution on what the difference is. If I use the settings on DBD124 --- the controller does not change it's behaviour, however if I change the DBD166 --- settings, then it changes.
I can't see what the PID settings in DBD124 --- are used for...
Thanks alot for any suggestions to make it a bit more clear..
Hi Sorry for the long explaination I am commisioning a new install with these PID control blocks which are supposedly auto tuning. The process...
7,489
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
97
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
295
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
105
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
160
