Siemens IL-70 PC Comms
Zombo
Nov 2003
PA
50
We have 2 Siemens IL-70 PC touchpanels
connected to 2 S7-315-2DP PLCs on seperate
machinery. The machines however are in a production cell. The connection is made through the X2-DP port via profibus.
Also we have a 3rd S7-315 in the same cell
on another peice of machinery. We have
Siemens simatic S7 programming software
installed on both IL-70's for editing or
troubleshooting. If possible how could a change made on one IL-70 PC be automatically updated on the other IL-70 PC? Right now if you make a programming change on one unit the other has a different program.
Here is a "relatively" simple way to do it:
Setup both PCs so that they are on the same network and so that they share a backup folder on one of the PCs (or better yet: A server drive).
Before editing the programs, allways use the "retrieve" function to get the latest version of the program.
When using the "archive" function, point to the shared folder for storing the .zip file. Use a version number in the filename and increment it everytime edits have been made.
I dont think it can be done 100% automatically.
Under Options ... Customize ... Archiving , the path for archiving and retrieving can be set.
Trying to integrate a new S7-1500 to an existing S7-300 PLC. Using the S7-1500 as an I/O Device. Trying to send some simple boolean tags between...
1,097
Hi, I'm investigating different network protocols for PLC to PLC comms, and PLC to SCADA. OPC UA seems to be a very useful protocol that I'm...
2,099
Hello, this is a brand new task for me. I recently bought a particulate sensor and it communicates with UART protocol or I2C protocol. It came...
2,869
I have a piece of equipment with control split between two PLCs. A quantum 434, and a Siemens S7-300, communicating via profibus. I have a prosoft...
5,331
Hi All, I have a Simens CU320 drive controller that I wish to connect to via the X127 ethernet port. The unit communicates with the CPU vua...
4,110
