Siemens Integer to String
JOLTRON
Aug 2006
MI
692
I am having issues with the Integer to String fuction (FC16) in my cpu 313.
My FC is running and my math before hand is being calculated but not getting anything out of my FC.
The line going into the FC is green but the actual FC is dotted blue like it isn't being processed.
Am I missings something simple.
Right now it's trying to conver 310 to a string. My string in my db is set to 3 characters.
Any ideas?
Thanks,
-Joel
From the Siemens help (F1) for FC16:
Description
The function FC16 converts a variable in INT data type format to a string. The string is shown preceded by a sign. If the variable given at the return parameter is too short, no conversion takes place and the binary result (BR) bit of the status word is set to “0".
You need space for the sign.
So if I'm looking to convert
DB40.DB22 - INT which equals 310
into a string
DB40.DBB32 - STRING[4]
DB40:
DBB32 - Max bytes
DBB33 - Actual bytes
DBB34 - sign????
DBB35 - 3 (char)
DBB36 - 1 (char)
DBB37 - 0 (char)
Is this the format of how the return sends the string?
I guess I'm missing something on how this returns data. I have tried a string of length's 3,4,5,6,10,254.
I thought it would just return the max, actual, sign and 3 characters.
Your analysis is correct. Note you cannot monitor a string in a DB - I've copied the string to chars to show what is happening.
I'm getting confused as to why mine is not working.
Here is a pic of my call for the FC. had to rename it my program already had a FC16. My string in my DB with a max of 4. and my empty VAT for that string. Do you see anything wrong with it?
Can you be sure that something else in your code is not overwriting the max string length - the only reason the ENO output from FC16 is false is when the string length is insufficient to take the resultant string.
Try the following code which writes a string to the temp data area. As its the temp area, the max length has to be loaded programmatically before the string variable can be used.
Set it up as Local with the manually seting up the header and it works great. Thanks for all your help.
I was using our training/testing station. There were some FC's in the PLC that weren't in copy I was using. So the DB was getting over wrote. My bad for not comparing first :(
I have a cognex camera that is transmitting a trigger id as an unsigned integer. However, everything in siemens displays it as a signed integer...
6,253
I am using Siemens Step 7 with an S7-400 Procesor. I am looking for a sleek way to count a number of bits and store the result as an integer...
6,399
I have never had the pleasure of working with a "Thermistor" until now and have a question. The Thermistor is a 10KOhm 4-20mA 2-wire device and I...
57
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
174
415
