Siemens Logo
pele1968
Feb 2005
Vancouver, Canada
Hello everyone, I am trying to program a Siemens Logo via the keypad & am having difficulty understanding the format... (boolean I believe?) Is there a way to change the programming to ladder logic like the Moeller EASY has? I do not have the programming cable otherwise I would use the Seimens software & do it that way...
Thanks in advance, Jeff
Hello Jeff,
If you want to change the format of programming in LAD you will need the Siemens LOGO Software, I`ll done some project with it.The mode of programing of logo is in FBD ( Function Block Diagram )which is via keypad. (y)
I`ll suggest that you buy Siemens Logo Software to your local siemens dealer. If you like you can download a free demo of it in siemens site.
Regards,
Sherwin
I've tried programming the logo using the keypad.
It's OK for simple programs, but when it gets too big I get lost.
I prefer ladder as well but have been told that once you get your head around FBD it is easier.
Daryl
I suggest you download the free demo from siemens website. The latest version supports ladder and FBD, you could program in ladder and use the software to convert LAD to FBD. Take a print and then feed the program using the key pad.
NOt the easiet way but i have done this a couple of times for long programs....
They sell a logo starter kit that has the software and cable with plc. It is a real pain to use the keypad to program, much easier to use pc.
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
300
Hi Lads, I want to implement a flood prevention system with my domestic water pump. The intention is to have the water pump cut off on a daily...
1,086
We need a Really Simple and Cheap controller that has a display or a Web Interface where we can change some set points. We were thinking about a...
1,053
hello i have LOGO! 12/24RCE and i am looking for a schematics of electronic board. Or if someone know what is the burned component on the photo.
1,418
Hi, I'm no expert in PID regulating so I need some advise. I have a VFD controlled deepwaterpump that is maintaining the pressure in a closed...
24
11,935
