Siemens Mp370
daevy
Jun 2004
Ooigem, Belgium
We have a Siemens MP370 connected to a S5-95U PLC using the IF1A-port.
Is it possible to add a communication with a Siemens CPU313C-PLC.
I have tried this already in WinCC-Flex, But then I have to change the communication with the S5-PLC from IF1A-port towards the IF2-port. Is it possible to communicate with this port??
We tried this with an OP270, same ports. S5 connected to IF2 (AS511) and S7 connected (MPI) to IF1B.
It works, but S5 update remains slow.
Just try it, it should work.
Hi guys, While trying to upgrade a Siemens MP370, it hung somewhere in the process and gets about halfway through the creation of its disk...
2,792
Need to put in a new touchscreen digitizer. Does anyone know the procedure or how difficult this might be? Have never taken one apart, so I don't...
1,416
Hi all, I have a problem with a Siemens MP370 touch panel. The original panel had a fault with the touch sensor, so a new unit was purchased to...
7,342
Hey i want to make a trend on a Siemens MP370 15 TOUCH 6AV6545-0DB10-0AX0 And need a storage card MP370 have USB-PC-card and CF-card, i wonder...
5,144
Hi all, I have a Siemens MP 370 15" touch HMI connected to an S7300 over MPI.. I have the source code application in WinCC 2005. I am trying to...
1,946
