Siemens Part Numbers
So, how do I check this in Step7?
Will I find it in the configuration . . . or am I going to have to look in the
function blocks or some other strange, weird, and wonderful place?
Just the hardware configuration in the properties of the module.
The High-Feature and Standard modules use the same amount of I/O area.
http://www.plctalk.net/qanda/images/attach/jpg.gif
Hopefully the picture from my configuration will be there.
Thank you SigmaDelta,
It does look like the Input addressing scheme (and numbers) are the
same for all three machines.
The 0AA0 type input modules do not have the 'Parameters' tab that
the 0AB0 input modules do.
Which leaves me with the output modules and
The successor part# is 6ES7132-4BD02-0AA0
Am I right in thinking that it should be a matter of changing the module,
then changing the part in the configuration (making sure the addresses
are the same as the old one)?
Again, many thanks guys.
Poet.
Yes.
Side note: you don't have to change the part number of 6ES7132-4BD01-0AA0 to 6ES7132-4BD02-0AA0... in this case, the new will behave as the old one without modifying the HW config because it is a direct replacement.
Poet.
Yes.
Right click on the module and you should have an option to replace the part with another.
Hello everyone, is there anyone who uses third-party panels with Siemens plc? Perhaps anyone have an experience. Any ideas. thanks
1,980
So I'm running a liquid filling operation and I'm trying to get the dribble valve to be open 100% for a time and then 20% for the rest. all that...
2,246
I am curious if anyone has working Data tracking of parts in a machine using siemens? I have made a few machines that use a compare DINT of the...
1,153
Hi, as a 3rd party repairer I work with Siemens Part Numbers on a daily basis, I often wonder what makes up a Siemens Part Number. Is their a...
6,139
Hi All, I am currently writing a new function in SCL, And I have a array at 300 bytes (tmpArray[0..299] OF Bytes) to this function. Questions...
3,432
