Siemens PC Based HMI
Jan 2016
Pakistan
I have an S7 315-2 PN/DP controller and I want to connect my WinCC HMI based PC (operator work station) through Ethernet. My question has two parts :
1- Is this the correct part no for my operator work station software ? Because I have to provide the client a runtime license.
6AV63812BN073AX0 (WINCC SYSTEMSOFTWARE V7.3, RC 512 (512 POWER TAGS), RUNTIME & CONFIGURATION -SW ON DVD, FLOATING LICENSE)
2- If I want to develop HMI Screens for my operator work station in TIA V13 SP1, do I have to add a WinCC RT Adv from Hardware Catalog into Simatic PC Station in the device view? Is this correct ?
Thanks and Regards,
You mention WinCC v7.3 and TIA v13 Sp1.
These are not directly compatible with each other.
WinCC v7.3 is the legacy SCADA software, though still used many places.
TIA v13 Sp1 is the current Siemens automation platform, and the PC based HMI software is either WinCC v13 Sp1 Advanced, or WinCC v13 Sp1 Professional.
The "advanced" version is the simpler "SCADA Lite", and the "professional" version is the full-blown SCADA replacement for WinCC v7.3.
To create HMI screens for TIA WinCC, you need the Advanced option or the Professional option for the TIA WinCC software. And for the target PC you need either a WinCC Advanced runtime license, or a WinCC Professional runtime license.
Hi, i want to design a HMI screen by TIA Portal and want to use it from my computer. is it possible? as i don't have any HMI hardware. Thanks
1,651
Hey guys, The TL;DR is the last two paragraphs with a web link for you to try yourself. If you don't have anything better to do, look at the...
17,035
Hi All, Looking for someone to help one of my customers with a very old Siemens S5 PLC that we need to try and get up and running again while we...
2,078
Greeting, I am doing some investigations on which driver(s) support tag based addressing (eg. Pump001_Running) rather than DB or Modbus based...
3,746
