Siemens plc and premium plc
Nov 2013
ahwaz
24
Greetings
I used Siemens PLC with CP343-1 (IP 192.168.0.1)
And also Telemecanique PLC(Premium) With ETY110ws (IP 192.168.0.2)
I used the function FB108 (Modbuscp) in Siemens PLC
And also the setting for the Netpro In siemens plc has been done.
Telemecanique PLC(premium) on-line mode is identifiable by Siemens.
For reading and writing data in Telemecanique plc how to act?
Siemens has also been used in Telemecanique plc(Premium) IP address
My problem is Telemecanique.
if I used DB11 in Siemens PLC with Start_DB:1 and End_DB:100 For Send to Telemecanique(Holding Rejester) (Settings in the FB108 in siemens are correct).
How will the data be received in Telemecanique plc (Premium)?
Do you have a specific Function (ADR) be used?
I used PL7 V4.4 and I canot use ADDM Function.
Greetings Can the Profibus network ، Schneider Premium PLC with TSXPBY100 Module was selected as Slave? I'm going SIEMENS PLC (S7-400) as master...
2,357
Greetings Is it possible that Siemens plc is a plc telemecanique cp343-1 module that is connected to the module ETY110ws able to exchange...
4,261
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
122
330
140
