Siemens PLC>PLC
YoungWint
Dec 2012
East Midlands
77
Hi All
Have a query regarding the how to communicate over Ethernet between to via three mediums.
First of all I need to communicate between PLCs on a network via PLC (CPU319-3) to PLC (CPU 319-3). What I want to do is set a DB in each PLC and read from each PLC. Which block(s)could I use for this?
Secondly I need to communicate between PLCs on a network via CP Module(Ethernet) to CP Module(Ethernet). Again What I want to do is set a DB in each PLC and read from each PLC. Which block(s)could I use for this?
Thirdly I need to communicate between PLCs on a network via CP Module(Ethernet) to PLC (CPU 319-3). Again What I want to do is set a DB in one PLC and read from the other PLC. Which block(s)could I use for this?
Any advice, examples etc. etc. appreciated as am struggling to identify the required blocks.
I have never had the pleasure of working with a "Thermistor" until now and have a question. The Thermistor is a 10KOhm 4-20mA 2-wire device and I...
33
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
163
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
382
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
119
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
167
