Siemens Plc Tcpip Communicaton
COLINDAVIES
Guest
C
I have been asked to provide a driver to interface with a Siemens S7/300 series PLC using a CP 343 ethernet card. I can talk to modicon and telemechanique PLCs using a TCPIP socket program, but when i try to use the same program with seimens, i fail to get a socket connecton.
I am told that i can use TCP Native or UDP
I can ping the PLC's IP address
I have very little experience of step-7 so i may have a set up problem
Has anyone ever tried this before, or is there a better way to go.
This is a preliminaryn query prior to going the S7 ie route
Hello ColinDavies;
You can ping the PLC's IP address because you have a correct physical setup; you cannot talk to the CPU through the CP343-1 because you are not using the correct protocol. Siemens' Industrial Ethernet is incompatible with Modbus/TCP (Modicon and Télémécanique) ot Allen-Bradley's Ethernet. The details are not within my level of expertise, I am talking from painful experience. We had to use OPC or protocol converters in different projects to get these different flavors of Ethernet comms to work together in different projects.
You can find details on Siemens' Industrial Ethernet on the Siemens support Website:
http://www4.ad.siemens.de/csinfo/li...nfo&wttree=productnodes&lang=en&objID=4000024
Hope this helps,
Daniel Chartier
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
205
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
192
353
169
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
953
