Siemens Profibus PA/DP Link with a third party PLC or gateway
grnick50
Nov 2010
Ptolemaida
332
Dear all,
In the past I have used DP/PA Links with Siemens PLCs. As both the Link and the PLC was from the same vendor, ther was no trouble building the network.
I have a new project where I need to use TH400 Profibus-PA temperature transmitters (47 of them) and I plan to use:
1 x 6ES71532BA020XB0 with
2 x 6ES71570AC830XA0
The thing is that this time the PLC will not be a Simatic PLC and it will probably be an AB Compactlogix. I plan to use this HMS Anybus gateway to add Profibus-DP functionality to my Compactlogix. My problem is how will I set up the GSD file for the profibus devices and I am not sure this setup is the best.
I had a look in this FAQ and I had written a post regarding the connection of a S7-1500 to a profibus-PA network but got no answer.
Has anyone used a Siemens Profibus DP/PA Link with a third party PLC? How did you work out the GSD file?
I think the AB7800 could work with the correct setup/configuration, timings etc. AB7800 will act as a PROFIBUS DP/DPV1 Master towards the PROFIBUS devices and an EtherNet/IP Adapter towards the CompactLogix PLC. With AB7800 a PROFIBUS Configuration software is included which you will be able to import all required GSD files in.
Send me an email on [email protected] and we can discuss further.
Markus
For one of the projects, Customer has Profibus Network as below, Profibus Master 1 - PRM Module (Schneider) addressed (1) Profibs Master 2 -...
3,344
Hi all, Im using a S7-319 PLC and on the profibus network i have a IM153 (6ES7 153-2BA02-0xb0) connected to this i then have 2 PA Couplers FDC...
2,914
Hello All, Does anyone here have any experience with a Mitsubishi Q series and Siemens 318-2 profibus DP link? I have the Siemens setup as master...
2,772
Hi, I have a Prosoft profibus master module (for control logix PLC) and the Siemens IM153-2 DP / PA link module (and the IM157 PA Coupler)...
6,594
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
563
