Siemens Protool Pro T Serial Port
DesertDog
May 2003
North of Los Angeles
350
I have a project using Pro-tool Pro on a Siemens Panel PC that talks to serial devices through the PLC. I find this very cumbersome requiring the screen to talk to the PLC then the PLC to the device and back. Not to mention how complex serial communications are through the PLC Comm Cards. In the past I have used WinWedge with InTouch to talk to several devices using USB to Serial converters. WinWedge does not work with Pro-Tool. Does anyone know of any easier method, perhaps some sort of VB - Active-X method?
I have USB/RS232C for my HP-Omnibook where is not RS232C-port.
Whit Pro-Tool.Pro there was only COM1 and COM2 ports available, so
USB/RS232C had to put to address COM2, COM1 was for MODEM-gate or something like that. Am I in the map ?
I am having trouble using ASCII text with the Allen-Bradley DF1 driver in Siemens ProTool/Pro. I am using a TP270 – 6” and an Allen-Bradley SLC...
5,469
Does anyone knows how to activate API function in Protool Pro? I want to activate WAV files (using VB scripting) in Protool Pro, using a PC as...
4,891
I am using Protool for the first time and I want to define different password levels. Protool supports only one password but it has an option to...
5,367
Hello, I am trying to break in into project from 2012 because it may require some modifications. Currently I am in stage of trying to understand...
2,404
I am trying to convert a Protool backup to WinCC 2008 SP2. I can start the migration wizard and the PDB file passes the consistency checks. But...
2,151
