Siemens Ratio_P block in CFC
ry_fern
Jan 2008
Caloocan City
44
Hey guys,
Good day!
I would like to seek for help regarding a CFC function block of siemens.
I am currently working on a project wherein I am using a Siemens S7-300 PLC and CFC for programming. It's my first time to work with CFC software.
Since this project is an addendum, there is an existing program that I can use to and modify some portions of it. However, I encountered this RATIO_P block. This block, after I imported it from the library, does not provide an output even if there's an input. I already configured some pins of it but still no luck. I am also looking for it's help file, but the software doesn't provide it. I even searched it on the internet, but I cannot find its use. Does anyone here know how this block works? or is there some help file for this block?
Thank you in advance.
Hey guys,
Good day!
Just becuse you connected an input to it doesn't mean you will get an output.Do you need an EN (enable) along with the rest of the parameters?
Most blocks rely on an enable signal as well as an input.
CFC, I'm not familiar with so can't help.
Hey guys,
Good day!
See the highlighted part above. Some pins?
What about the rest of the pins?
Thank you guys.
@bkottaras,
yes, I configured some of the pins, and also tried to enable other pins. The ENO and EN block are hidden but can be showed if they are marked "watched".
@JRW
Yes this is a Siemens block, I already found some info at siemens that this is a siemens block. However, it's use, I cannot find.
Ratio_P is under the Control library, the author is TECHNO 60, internal identifier is FB70.
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
52
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
33
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
139
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
171
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
178
