Siemens Remote I/O
31415927
Guest
I am confused about the SIMATIC ET 200M modular I/O station.
Can this be used with a S7-400 PLC as a master? Or just with
a S7-300 SERIES PLC? Does anyone have a sample project
layed out with using the modular I/O?
If a PLC is a Profibus-DP master then you can use any Profibus-DP slave I/O with it. So if you have a Profibus-DP-capable S7-400 CPU then you can use ET200M. Conversely there are some S7-300s which don't have DP capability so you can't use ET200M with them.
Be aware, the actual I/O modules can be used in different configurations -
- S7-300 CPU racks use these modules directly as part of the I/O structure.
- S7-300 expansion racks (connected to the CPU rack using IM360/361 interface modules for example) use these modules directly as part of the I/O structure.
- ET200M Profibus-DP slaves (connected to a DP master using an IM153 interface module) use these modules.
Whether you regard them as S7-300 modules or ET200M modules depends on the application.
Regards
Ken.
You can experiment with the configuration without really having an S7-300 or ET200M at hand.
In the Hardware configuration of STEP7, pick a CPU with a Profibus port, or add a CP342-5 to the S7-300 rack.
Then enable the Profibus port.
A Profibus network will appear (it is just a "wire" in the HW config).
Highlight the Profibus network, and then add an ET200M and corresponding i/o modules.
Experiment with other Profibus setups. Try ET200S, and some MicroMaster drives etc. etc.
Siemens S7/TIA v18: "Remote" updates/bug fixes to PLC code & HMI screens..... Hi, The PLC application I'm working on will soon be delivered to...
598
Any manufacture recommendation for remote I/O for Siemens PLC.
2,934
Hi, I want to setup somekind of server in ALM so that I can start Tia portal on any connected PC and borrow the license automatically. Is this...
1,429
Hi, Here is my dilemma - I hope somebody has done this before. This involves equipment in three different locations (and countries). On site...
6,072
Hi, I have a question about Siemens ET200M series modules. These will be used in a remote IO panel. In this panel will be a dual redundant Siemens...
1,343
