Siemens S200 Connection Cable
Brian H
Oct 2005
Fuengirolla
I am about to order the software needed for programming S200 PLC's.
Will my MPI card/ connector cable used with S300 and S400 PLC's work with a s200 PLC. Or do i need to buy the specific PPI cable for the S200.
I don't think its needed. All you need to do is change the settings on "Set PG/PC interface" to the correct one. The software might ask you to set the PG/PC interface while installing. You could do it later too..
if u have the rs232/mpi u should have another one
but i know that there is a usb version for this cable that works both i can give u its part number if u need it
Good morning,
Just to clarify, when you say MPI card do you mean a CP5511 pcmia adaptor because you can set that up to work with a 200, but if you have an serial MPI adaptor then it will not.
Good day guys (and gals) I have a question about what is required to get an analog output from a em232 analog output module connected to an s200...
6,098
2,584
Hi, I'm currently trying to connect a Redlion DSPSX to a Siemens S200 PLC. I can ping the S200 PLC and the DSP but I cannot get the two to talk...
4,441
Hi, I have a Allen Bradley 1756-L61 PLC and 5 Siemens S200 (processor S226). I like to transfer data between all these PLCs. Is there a way to do...
6,187
Hello All, I am hoping someone can help me out since I know Jack about Seimens PLCs. I have been given the task to figure out if a Siemens s7-200...
4,610
