Siemens S5 Retentive Timer
advocar
Mar 2004
Siemens S5 PLC Timers. Have looked through manual re types of timers There are 5 timer types in Simatic S5 (pulse, extended pulse, On delay, retentive On delay, Off delay) and 2 counter types (Up and Down).
The retentive timer looks Ok at first but appears to hold values if power is lost only.
I need to enable a timer when flag 1 goes false. Then accumulate run time of a motor output Q xxx that stops and starts until a preset has been reached. Then I want to reset a flag 2.
If Flag 1 goes true and then back to false before preset reached I need to reset any accumulated time to zero
Note the current logic is in a PB block called via a Jump call.
Have I missread the retentive timer function, or do I need to add the run time into a counter? If so would I need to do that in a FB block.
Siemens S5 timers. Thanks for reply.
Not at work 9pm NZ time.
If I remember correctly
A LDW 225
AN F33.7 T 225
A225 R F33.0
When looking online
F33.0 was switching viewed on RLO.
Timer preset displayed correctly
But I could not see it counting down when F33.7 toggled
Looks like I may not be entering the correct setup into the PLC code
Will look into it at work tomorrow. In at 3am to try and fix it?
hey friends,
i need some help. what means (type timers) SE and SD
the timer SD means Timer On-Delay, right? and that timer SE? Whats the diference?
for example:
A I 1.2
O F 99.1
L KT 0015.2
SE T001
yes, i know. but i have to do a conversion to S5 project for RSLogix 5000 and the software S5 don't have help instrutions. What's the difference that SE for this SD?
regards
Miguel
First off, thanks for the patience with my post. Rookie to Siemens. I am trying to use a Retentive timer and it has to be around 24hours. Thus...
1,889
does anyone know how to prog a retentive timer in step 5 statement list ? AB has a RTO, siemens have no such thing (SP, SE, SS,SD & SF)
8,754
Having trouble with a Siemens S7 226 counter being retentive. I have specified in the System block C ranges offset 0, 6 elements. However, at...
283
I have a small project running on a S7-1500. In the program is a bit %MD66 which is a value input from an HMI. I want to make this value retentive...
3,200
Am I correct to think the Offset is the start and the Number of Elements the end? MB Offset = 14, Number of Elements = 18 Means, MB 14 to MB...
1,673
