Siemens S5
USSA
Apr 2009
Sharjah
Dear Friends I am interesrted in learning Siemens S5 PLC Programming , can any body tell me where can I get software for this.
Why would you guys want to learn the Old S5 stuff when S7 is pretty much the way to go ?
Would it not be more beneficial to learn the S7 stuff as you can always use the basis of that when and if you ever came across a old S5,s
Not sure about this "passing around the software" bit though!
IF this software is bootlegged I'm sure it is illegal. But if they want to take the consequences... It surely is very stupid to offer illegal software by providing your emailaddress. It is equivalent to telling the cops where and when you're planning to rob someone.
But if the supplier is a bonafide dealer, there's absolutely nothing wrong with this offering. The passing around bit surely IS illegal.
Regards,
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
98
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
300
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
106
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
160
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
197
