Siemens S5
leka
Oct 2010
Aarhus
Hi
I have to make a change in this plc program but have not seen such a kind of programming before. Are there some who can tell me how this works?
I have never seen this block either. Is it a standard block from Siemens? If you check the library number, it might reveal something. Are there any IPxxx-cards in the system?
Here is the link to S5-software manuals from Siemens. Many are old, and therefore scanned to PDF. The search function does not work so you will have to read carefully.
đź“š
Kalle
It's probably not a siemens standard block if you can open it & see past JU=m001, most siemens blocks were protected however they did write some & left them open.
Most siemens standard blocks were 200-255
The code for FB121. it looks complicated!
[1
DECL: DBNR DKY
DECL: PACT DKF
DECL: PBAD DKF
DECL: PGOO DKF
DECL: NRNI DKF
DECL: NRCT DKF
DECL: CTRL IBI
DECL: SYNC IBI
DECL: OPTI DKM
DECL: INIT IBI
DECL: MEMO IBI
DECL: NMES DKF
DECL: NMEI DKF
DECL: STAT QBY
DECL: FAUL QBI
DECL: INSP QBI
[2
LW =PACT
T FY 200
LW =NRNI
T FY 201
L KF +1
T FY 218
L KH 0000
T FW 210
[3
LW =DBNR
T FW 212
L FY 212
T FW 214
DO FW 214
C DB 0
L DW 10
L FY 213
+F
T DW 18
DO DW 18
L DW 0
T FW 220
[4
AN =INIT
O F 220.0
JC =M001
L KH 0000
T FY 220
JU FB 72
FCT : KF +1
TYPP: KH 0088
PBAS: KF +2
NPS1: FY 200
NPS2: FY 201
PREC: FY 210
CREC: FY 210
POWO: FY 210
PONX: FY 204
STAT: FY 206
L FY 204
L FY 200
!=F
S F 220.1
>=F
JC =M002
JU FB 71
FCT : KF +1
TYPP: KH 0012
PBAS: KF +2
NPS1: FY 200
NPS2: FY 201
NPC1: FY 210
NPC2: FY 210
ONOF: FY 210
BOMA: FY 204
CODE: FY 210
VIDA: FY 205
SERI: FW 208
STAT: FY 206
L FY 204
L KF +1
!=F
S F 220.2
L FY 205
L KF +1
!=F
S F 220.3
AN F 220.2
O F 220.3
JC =M003
JU =M004
M001: JU =M005
M004:
LW =PBAD
T FY 212
JU FB 72
FCT : KF +2
TYPP: KH 000C
PBAS: KF +2
NPS1: FY 200
NPS2: FY 201
PREC: FY 210
CREC: FY 212
POWO: FY 200
PONX: FY 212
STAT: FY 206
L KH 00FD
T FW 212
JU FB 71
FCT : KF +2
TYPP: KH 0030
PBAS: KF +2
NPS1: FY 200
NPS2: FY 201
NPC1: FY 210
NPC2: FY 210
ONOF: FY 210
BOMA: FY 212
CODE: FY 213
VIDA: FY 210
SERI: FW 210
STAT: FY 206
JU FB 65
FCT : KF +2
TYPE: KH 0001
NRPO: FY 200
NRST: FY 218
ONOF: F 110.0
BOMA: F 110.0
AN F 221.7
S F 221.7
M002:
JU FB 71
FCT : KF +1
TYPP: KH 0012
PBAS: KF +2
NPS1: FY 200
NPS2: FY 201
NPC1: FY 210
NPC2: FY 210
ONOF: FY 210
BOMA: FY 204
CODE: FY 210
VIDA: FY 205
SERI: FW 208
STAT: FY 206
L FY 204
L KF +1
!=F
S F 220.2
L FY 205
L KF +1
!=F
S F 220.3
M003:
JU FB 61
FCT : KF +1
TYPP: KH 0002
NRPO: FY 200
NRST: FY 218
TYPE: FY 210
ONOF: FY 204
SERI: FW 210
MAPA: FY 205
COPA: FY 205
PREC: FY 205
STAT: FY 206
L FY 204
L KF +1
!=F
S F 220.6
L FW 208
L FW 210
!=F
S F 220.5
AN F 220.0
S F 220.0
M005: ***
[5
LW =OPTI
T FW 202
[6
AN =MEMO
ON F 220.0
JC =M001
AN F 220.1
ON F 220.2
O F 220.3
JC =M002
LW =PGOO
T FY 207
AN F 220.6
O
A F 203.4
AN F 220.5
O
AN F 221.1
O
A F 221.1
A F 221.2
JC =M003
LW =PBAD
T FY 207
JU FB 65
FCT : KF +2
TYPE: KH 0001
NRPO: FY 200
NRST: FY 218
ONOF: F 110.0
BOMA: F 110.0
L KH 0001
T FW 204
L KH 0000
T FW 210
JU FB 71
FCT : KF +2
TYPP: KH 0030
PBAS: KF +2
NPS1: FY 200
NPS2: FY 201
NPC1: FY 210
NPC2: FY 210
ONOF: FY 210
BOMA: FY 204
CODE: FY 200
VIDA: FY 210
SERI: FW 210
STAT: FY 206
M003:
JU FB 72
FCT : KF +2
TYPP: KH 000C
PBAS: KF +2
NPS1: FY 200
NPS2: FY 201
PREC: FY 210
CREC: FY 210
POWO: FY 200
PONX: FY 207
STAT: FY 206
M002:
L FW 220
L KH FE00
AW
T FW 220
M001: ***
[7
A =CTRL
= F 221.0
[8
AN =SYNC
O
A F 221.1
AN F 221.2
JC =M001
AN F 221.1
S F 221.1
S F 221.2
A F 221.0
A F 202.0
O
AN F 221.0
AN F 202.0
R F 221.2
M001: ***
[9
A =SYNC
ON F 221.1
O F 221.3
JC =M001
LW =NRCT
T FY 213
L KH 0000
T FY 207
A F 220.1
A F 220.2
AN F 220.3
A(
A F 220.5
ON F 203.4
A F 220.6
AN F 221.2
JC =M002
JU FB 63
FCT : KF +4
TYPP: KH 0000
NRPO: FY 200
NRST: FY 218
NRCT: FY 213
INCR: FY 210
CPTJ: FW 210
CPTC: FW 210
CPTP: FW 210
FLGP: F 207.0
FLGC: F 207.1
STAT: FY 206
JC =M003
M002:
JU FB 63
FCT : KF +6
TYPP: KH 0000
NRPO: FY 200
NRST: FY 218
NRCT: FY 213
INCR: FY 213
CPTJ: FW 210
CPTC: FW 210
CPTP: FW 210
FLGP: F 207.2
FLGC: F 220.7
STAT: FY 206
L KH 0100
T FW 214
A F 220.7
JC FB 61
FCT : KF +2
TYPP: KH 0030
NRPO: FY 200
NRST: FY 218
TYPE: FY 210
ONOF: FY 210
SERI: FW 210
MAPA: FY 214
COPA: FY 215
PREC: FY 210
STAT: FY 206
L KH 0000
T FY 204
JU FB 71
FCT : KF +2
TYPP: KH 0030
PBAS: KF +2
NPS1: FY 200
NPS2: FY 201
NPC1: FY 210
NPC2: FY 210
ONOF: FY 210
BOMA: FY 204
CODE: FY 200
VIDA: FY 210
SERI: FW 210
STAT: FY 206
JU FB 73
FCT : KF +3
PBAS: KF +2
NPS1: FY 200
NPS2: FY 201
NRCT: FY 213
INCR: FY 213
VCNT: FW 210
STAT: FY 206
M003: AN F 221.3
S F 221.3
A F 220.7
S =FAUL
M001: ***
[10
A =FAUL
= F 220.7
S F 115.3
[11
A(
A F 221.0
AN F 202.0
O
AN F 221.0
A F 202.0
A F 202.7
A F 80.4
S =INSP
AN F 202.7
RB =INSP
[12
A =INSP
S F 115.3
[13
A(
AN =FAUL
AN =INSP
O F 120.7
O F 114.4
ON F 80.0
JC =M001
LW =CTRL
L KH 0FFF
AW
T FW 204
L FY 205
T FW 210
L KF +10
T FW 212
JU FB 242
Z1 : FW 210
Z2 : FW 212
Z3=0: F 217.0
Z32 : FW 216
Z31 : FW 214
L FY 204
L FW 214
+F
T FW 216
A =INSP
JC =M002
LW =NMES
T FY 210
LW =FAUL
JU =M003
M002: LW =NMEI
T FY 210
LW =INSP
M003: L KH 0FFF
AW
T FW 212
L FW 200
T FW 214
JU FB 21
NMES: FY 210
REP : FW 212
STAT: FW 214
CAPT: FW 216
RES1: KF +0
TYPE: KY 1,3
FLAG: F 120.7
M001: ***
[14
L FY 220
T =STAT
[15
L FW 220
DO DW 18
T DW 0
[16
BE
The DO instruction is indirect addressing.
for example
'L FY 212
T FW 214
DO FW 214
C DB 0'
The DB address is passed to FW214.
If FW214 = 50
Then
DO FW 214
C DB 0
Will open DB50.
It's not that complicated but unless you know what it's supposed to do it could be difficult to decipher.
DO instruction
Like DO FW200
Call DB0
if flagword 200 contains 123 then the call DBO calls Datablock 123
It's a way of calling blocks indirectly so you pass the DB number to scratch flagword then call the block with that number
This can be done using dw in other db's flags etc.
You can also put the MC5 (raw machine code) code for an instruction in a FW then do the flagword then do a system instruction i.e. if 5CEF is the MC5 code for L Timer 5 then putting Hex 5CEf in FW200
Do FW200
L RS0
would load T5 (before anyone comments I know the hex code is wrong but lost my MC5 instruction set years ago)
Trying to trace the pointers could be very difficult as they could be changing all the time.
I have seen code that uses this type of indirect instructions to change code at runtime (very dangerous in my oppinion).
Okay thanks for imput. I vil try to read your examples in the program
@kalle
The task is too add a redcontact to one of the stations on the machine. The machine is a NUTT & JAGGI with 30 stations on. So I'm trying to figure out how the program works before I do anything.
Good morning, all I am very new to siemens family and to STL, i have been playing for two days now and manage to get the scaling do in STL. Now...
Hi! What is the way to convert the code from the Codesys code to the Tia Portal? Regards, WK
85
Good Afternoon , It has been decades since I have done anything with Siemens . What is the Siemens name of their Servo Product Line and what...
210
I'm using the Siemens PRONETA software to do some IO testing currently. I love the simplicity and fast testing capability. Does anyone know about...
88
Hi, First time user of S5 Siemens. Is there any solution on how to solve this kind of error. HMI OP7 $613 DB-error No. 11 (0: 15) Siemens PLC...
173
