Siemens S7-226 PLC questions
Scott-bc
Oct 2008
Vancouver
We are working on a project where we were able to get rid of an obsolte Festo PLC and replace it with a Siemens S7. Couple of qiestions:
1. We have a Redlion standard duty encoder that we want to wire into the S7. In the specs it says it can handle a high speed counter encoder input. Is this right?? The encoder will be used for position control. Based on the amount of counts it will tell us where our equipment is.
2. Because money is tight on this project we might not use an ethernet module(CP243-1IT) instead communicate PPI(RS485) between the PC running the WinCC flexible runtime and the S7 PLC. Cable distance is about 50 feet. If speed becomes an issue then we might need to use ethernet comms. Anybody have experience with this??
Thoughts and suggestions are welcome. Thanks.
The high speed inputs will go up to 20kHz in two phase input mode, so as long as you are getting less than 20000 pulses per second from the encoder then you will be OK.
Don't have experience on the ethernet modules though you could probably cut the cost by not using the IT version.
Regards
Bryan
Its a S7-200 part # 6ES7 216-2BD23-0XB0 A customer sent me one of these to extract the program out of. I have zero experience with Siemens S7...
2,239
Hi; Can anyone please explain me the difference between Siemens PLC CPU226 6ES7 216-2AD22-XB0 and CPU226 6ES7 216-2AD21-XB0?
2,348
hello once again im here asking a beginner question does anyone know how much current does the internal power supply (24v)from the siemens s7...
3,690
Hello guys, i am new on this forum, i need help in programming siemens s7 200 with micromaster 420 that is connected with motor. I know how to...
5,119
Simply put..I have a Siemens CPU226 with 2 comms ports. Currently one is used for the HMI and the other for Online programming. I have a Barcode...
1,988
