Siemens S7 315 PN/DP CPU Status LED's
slp530
Feb 2007
newcastle
49
Hi All.
I'm creating several diagnostic screens for the maintenance personnel, displaying the I/O status.
Do you know if it's possible to get the status of the CPU LED's i.e RUN, STOP, SF, BF, FORCE, MAINT etc. and display these overlaid on a picture on an HMI. this was very simple for the I/O and Analog, but I can't find out where to get the CPU LED status.
Thanks for looking.
Steve
I like your idea, would you be willing to share your program?
@Lare, thank you. I did google for the info, but as usual with google it's the way you ask the question.
@boneless. No problem, i just grabbed some screen shots after zooming in after i configured the hardware in TIA. The boring part was addressing the animations i drew on the picture. I will send you the relevent screens if you wish.
br
Steve
I'll preface this by saying this is the first time I've worked on a Siemens system and I'm fairly unfamiliar with them. I might mess up some of...
29
859
Hi We were having a few power cuts and the CPU would not work. I had to reset the memory and he CPU would read from the memory card and start...
3,228
Hi, Can anyone explain the difference between rebooting a Siemens CPU 315-2 PN/DP, either by setting the switch into stop and back into run...
2,744
I have a Siemens S7 300 CPU 315-2 PN/DP PLC and CP 342-5. IM Module is configured via ethernet port. I have two profibus network. One on CPU and...
4,171
Hi i Have an OP7 [6AV36071JC200AX1] and a CPU s7-315 DP [6ES73152AF020AB0] I'm communicating between the two via DP, i need to set up the CPU so...
1,412
